Newbie Wrong Voltage whoops....
Results 1 to 3 of 3
Thread: Wrong Voltage whoops....
    Mar 2005
    Default Wrong Voltage whoops....
    OK I'm an idiot, I was doing some rewiring and I accidentally wired 120v with 240v and it blew a variristor. So I replaced the variristor and wired it properly but now the servo drives won't power up. Is there something I am missing it seems like everything else in the panel is fine.
    Any input would be greatly appreciated.
    Thanks Mike
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Wrong Voltage whoops....
    Check the parts with a meter, starting with the power circuits: fuse, diode bridge, output transistors. Measure the voltage on the big capacitors (very carefully). If everything is fine there, check the low voltage power supply.
    Mar 2005
    Quote Originally Posted by CitizenOfDreams View Post
    OK thanks for the reply.
