That Fotek relay can be used for 220VAC ?
Currently using a solid state relay with input 3-32 VDC, Output voltage 24-380 VAC and Output current 25A to power on/off 1 HP 110 volt electric motor. The current relay has only one connector for the 110 volt input and load side wire. I want to upgrade motor to a 3HP 220 volt . Any thoughts on a solid state relay which will work for this 220 volt application? Can I add another relay and use in parallel?
You could use 2 of those to switch both sides of the 220 line. I have not seen a single solid state relay with two line and load terminals.
Jim Dawson
Sandy, Oregon, USA
You could use a contactor.
UCCNC 2017 Screenset
how about a dual SSR
basically two solid state relays in one package
for 3 phase motors you have these 3 phase SSR's
3 Hp is only 2.2Kw so at first sight a 25A rely will be OK
but you need to have a relay that can withstand the start up current
just beware from places like ebay some of the solid state relays are fake !!!
John
Mactec54
