NPN NO proximity sensor resistor enquiry
Results 1 to 12 of 12
Thread: NPN NO proximity sensor resistor enquiry
    Feb 2013
    uk
    Default NPN NO proximity sensor resistor enquiry
    I am planning to use proximity sensors for my home and limit switches for Mach3. NPN NO sensors. They will be supplied by 24v going to a generic 5 axis board ( 5v)
    Am I correct in thinking that means the black wire to the BOB from the sensor will also be receiving 24v, which will potentially damage what is a 5v board?
    If thats the case should I not add a resistor somewhere to lower the voltage from 24v to near 5v to the BOB?
    Any info or links most welcome.
    Thanks.
    Feb 2013
    uk
    Default Re: NPN NO proximity sensor resistor enquiry
    Proximity spec
    Set up distance 0 - 3.6mm
    Detection objete Magenetic
    Effective voltage DC: 12 - 24V AC: 110 - 220V
    Detection distance 4mm± 10%
    Response frequency DC:0.5kHz
    AC:25Hz
    Working voltage DC:6 - 36V
    AC: 90-250V
    Control output DC: NPN / PNP:?300mA DC 2 wire:?200mA
    AC :400mA
    Loop protection DC :reversal connection protection protection, surge avsorption ,load short-circuit protecrion
    AC : surge avsorption
    NPN NO proximity sensor resistor enquiry-npn-wiring-png
    BOB
    NPN NO proximity sensor resistor enquiry-upgraded-5-axis-cnc-controller-interface-adapter
    Member john-100's Avatar
    Mar 2007
    uk
    with the BOB in your photo you don't need the pull up resistor shown in the diagram
    NPN NO proximity sensor resistor enquiry-ebay-cnc-bob-jpg
    John
    PS
    NPN NO proximity sensor resistor enquiry-limit-switch-connections-jpg
    Feb 2013
    uk
    Excellent info thanks!
    Just out of interest is the db25 1205 BOB also optoisolated for the same proximity sensors?
    Mar 2007
    uk
    yes
    the 5 inputs to the PC printer port (or motion controller ) are opto-isolated
    the 12 printer port outputs are not isolated but they are buffered by two 74HHC245 IC's that ensures there is enough current drive
    to the opto-islaters inside the stepper drivers
    note-
    the limit switch common is connected to the PWM 0-10V analogue spindle comtrol common
    so you will need to ensure the spindle speed control VFD you use has an input that is isolated from the mains
    John
    ericks
    Guest
    I have the same bob....just be aware that the lm317 gets quite hot when you use 24 V
  7. #7
    Feb 2013
    uk
    Quote Originally Posted by john-100 View Post
    note-
    John
    Now thats interesting! The GND pin suggested to use as the common on my blue board doesnt seem to work so i'm using the GND next to the 5V in. Good point about limit switch common is connected to the PWM 0-10V analogue spindle control common, I didnt know that.
    I'm using a less well known VFD, an XSY-ATI. No idea about the isolation, the BOB is wired to the VFD on the control side. Spindle ON/OFF is fine but speed not working in Mach3? the two things might be connected.
    NPN NO proximity sensor resistor enquiry-xsy-ati-dia9-jpg
  8. #8
    Feb 2013
    uk
    Quote Originally Posted by ericks View Post
    Good to know. Perhaps it would do not harm to add a 3.3k resistor, which would take the voltage down to around 5.8v or something. The Im317 would like that
  9. #9
    ericks
    Guest
    I am just using 12 V, you don't want less than 12V! Your pwm to voltage converter requires more than 10 V
  10. #10
    Feb 2013
    uk
    Ah right your talking about pwm to voltage convertion. More than 10v. Gotcha!
  11. #11
    Mar 2007
    uk
    If I converted my mini lathe with a spindle motor speed control more like this KB electronics board or a clone
    NPN NO proximity sensor resistor enquiry-kblc-240d-jpg
    NPN NO proximity sensor resistor enquiry-kbic-240d_board-jpg
    the entire circuit board is live
    and you need a BOB with a PWM to analogue control that is isolated from the rest of the BOB
    some thing like CNC4PS's C6
    NPN NO proximity sensor resistor enquiry-c6-variable-speed-control-board-jpg
    John
  12. #12
    Feb 2013
    uk
    the entire circuit board is live and you need a BOB with a PWM to analogue control that is isolated from the rest of the BOB
    John
    Ok good point. I need to look into what the both BOB's I have are fitted with. At the moment I am wired to the VFD as per the image below.
    NPN NO proximity sensor resistor enquiry-cnc-breakout-board-rockcliff-machine-inc-cnc
