- Simple cnc 3-axis CTRL with PWM and manual control
Spec:
- 3axis (for isolated drivers)
- board dimensions: 107 x 80 x 15 mm
- supply voltage / current: 12-32VDC / 0,5A
- communication port: LPT
- Connectors: Molex MiniFit 2,3 8 pin, Driver connector: Molex 2.54 4-pin
- optical indication of output stages (LED)
- Spindel RPM and direction controll (0-10V)
- Cooling output (NPN, 12V/1A)
- Index input (RPM spindle sensor)
- Probe input (NPN)
- limit SWITCH INPUTS (paraleLL, NPN)
- ESTOP INPUT (+12V)
- man SWITCH: CNC / manual
SW: Linux CNC, MACH3, OTHERS supporting LPT port
VIDEO
Images
Attachment 393109
Attachment 393111
Attachment 393113
Attachment 393115
Attachment 393117
- You may not post replies
- You may not edit your posts
Forum Rules
