The charge pump can be used to Enable On / Off for all Drives and Spindle as a Safety circuit , most don't use it as they use other ways to create a safety circuit
The Charge Pump circuit would turn on a relay that could be used to Enable your Drives Spindle Etc, or could also be connected into the Estop circuit also
