Chinese 5 axis BoB not working with oh137 Hall Effect Sensor
Results 1 to 2 of 2
Thread: Chinese 5 axis BoB not working with oh137 Hall Effect Sensor
    Default Chinese 5 axis BoB not working with oh137 Hall Effect Sensor
    Hey guys,
    I'm using This Board Here
    I'm trying to use an OH137 Hall Effect Sensor as a limit switch on the X axis of my lathe using LinuxCNC. I previously had a mechanical switch in place, however I was having repeatability issues.
    I've attached a picture showing how I have it wired up. I have the output wire going to pin15 on the board. And 5v and ground going to those pins, along with a 1k ohm pull up resistor bridged between 5v and output.
    I've also set the pin to active low in the software.
    I've checked everything with a multimeter and it the 5v drops low when a magnet is near it so the oh137 itself is working.
    Another thing I've tried is using the ground next to pin15 but that didn't make a difference.
    Anyone here with electronics experience know where I'm going wrong?
    Chinese 5 axis BoB not working with oh137 Hall Effect Sensor-5-axis-cnc-breakout-board-interface-mach3
    Attached Thumbnails Attached Thumbnails Chinese 5 axis BoB not working with oh137 Hall Effect Sensor-5-axis-cnc-breakout-board-interface-mach3
    Dec 2012
    Netherlands
    Default Re: Chinese 5 axis BoB not working with oh137 Hall Effect Sensor
    take your multimeter in resistor ( Ohm ) position and verify if the ground on the inputs is connected to the ground of your OH137. If not, connect a wire between these two and leave the other as in your diagram. Try again and it might work
