KBIC DC Motor Speed Controller
Results 1 to 8 of 8
Thread: KBIC DC Motor Speed Controller
    Member kolias's Avatar
    May 2009
    Default KBIC DC Motor Speed Controller
    The attached picture indicates a schematic from Al the Man who did it to help me back in 2012 to connect a Sherline 90VDC motor with a KBIC controller and all went fine at that time.
    I have the same Sherline 90VDC motor with the same KBIC controller which now I try to connect for a new Taig lathe I bought. Since for now I just want a simple ON/OFF control I follow the schematic but I don’t connect the white and orange wiring from the motor which are going to the relay. I just connect the red, black, green from the motor to KBIC and the AC power white to L1 and black to the switch inside the KBIC. The motor white and orange are tapped off as per schematic
    I also want to control the speed with the knob on the KBIC.
    When I turn the KBIC switch to ON I just hear a humming noise and the motor doesn’t turn
    What I do wrong?
    Attached Thumbnails Attached Thumbnails KBIC DC Motor Speed Controller-als-sherline-motor-wiring2-jpg
    Nicolas
    Dec 2003
    Default Re: KBIC DC Motor Speed Controller
    I had to do some searching to jog my memory, IIRC the white - orange pair are the thermal switch, so it should run without it.
    Have you proven the motor is OK by running it on an automotive battery for example?
    Did you connect the speed control correctly ?
    May 2009
    Thanks Al
    The humming noise comes from the KBIC box so I suspect the problem is in there
    My car battery is kind of difficult to access, got to find another way
    Connecting speed control correctly? How do I check that?
    BTW the orange and white wires inside the KBIC are not connected to anything
    Nicolas
    Dec 2003
    The orange - white are just a thermal sensor to detect overheating.
    You could wire a lamp in place of the motor and see if you go from off gradually up to full brilliance.
    May 2009
    I wired a 12.8VDC, 1.3A transformer to the motor and it turns
    I wired a lamp to the KBIC and the light goes up/down with the knob
    Again from the motor I connect black, red and ground to KBIC and from AC power the white to L1 and the black to the switch on KBIC, is simple but doesn’t work
    Any more ideas?
    Nicolas
    Dec 2003
    So you have the AC in going to L1 & L2 ?
    Measure the resistance from the motor black and motor red to the Ground lead.
    I assume the KBIC did not hum with the lamp test?
    May 2009
    Yes the AC black is going to the one side of the switch and the other side of the same switch goes to L2.
    Correct, the KBIC didn’t hum with the light bulb
    Something I thought Al. The KBIC / Motor was used before by another guy and he replaced them with a VFD and afterwards he gave me the KBIC / Motor since he has no use for them. I’m thinking he may have palyed with the potentiometer and the settings may have change and that’s why I hear a hum from the KBIC. The manual says to check the voltage between P1 and P3. What voltage is on these terminals? (DC or AC) so I can check and adjust
    Nicolas
  8. #8
    May 2009
    All is good now Al, it was the trimpots MIN/MAX adjustments. I just set them as per manual and now the motor starts and the speed knob controls the speed nicely up/dn
    Much appreciated
    Nicolas
