It is often done with a AMP CPC connectors using a dedicated pin for the GND.
Pretty exciting that I'm finally getting around to my mill conversion. I've been trying to read up on all the conventions about control panels by the majors but can't seem to tackle these.
- Am I able to carry 'shielding' through connectors to terminate inside the control box, or do I need to use glands and terminate? I feel like this would be piggy backing the shield defeating the purpose. They will only be grounded on one end as per usual once inside the enclosure (plastic ABS)
If yes, what style of connectors are capable, or can I piggy back it through a pin - such as an AMP CPC?
- Is piggy-backing the shield to a ground terminal bar (from a sub bar to main) not effective (and does the unshielded wire pick up extra noise on the way)?
External VFD is planned, all control and low voltage power is shielded. AC mains will be either twisted pair or shielded. Taking on star point grounding, limiting noisy/quiet cable interaction etc. EMI filter if needed.
Thanks in advance!
Your Box being Plastic, there would be no point in a Gland for the Shields, but you could use a regular wire restraint, you will need a aluminum back plane that you mount everything on this Plate will be earth/Grounded, with your main power supply Ground to you cabinet,your shields will terminate directly to the metal Plate/Back Plane some snips on how you need to terminate the Shields
Mactec54
I meant glands as they would keep the shielding intact (rather than cutting and using a connector) and then being able to terminate in the ways you posted
So having the ground through a pin, then connecting the pin back to the shield, and then terminating at the end isn't a bad option (as long it doesn't create a loop)?
Just some final yes/no's before I don't do something ineffective against noise, would this layout render useless to shielding because of that piggy back wire to the GND point (as well as the soldered wires through the connector pin & terminal block)?
Or would a small gnd plane at each appliance (3 max) with full contact be better, then to full contact connect the sub-planes to a main star ground (while avoiding loops)?
As suggested using a dedicated pin to carry the shielding would work for almost any connector?
[QUOTE=Imjay;1942548]Just some final yes/no's before I don't do something ineffective against noise, would this layout render useless to shielding because of that piggy back wire to the GND point (as well as the soldered wires through the connector pin & terminal block)?
As suggested using a dedicated pin to carry the shielding would work for almost[URL="https://www.aliexpress.com/item/Free-shipping-3Pin-Waterproof-Connector-IP68-Cable-Connector-Plug-and-socket-connectors-auto-electrical-connectors-SP1[/QUOTE]
Just ( 1 ) Sub Plate/Ground Plane, with the shields clamps mounted directly to the plate, this Plate then has you Mains Power supply Ground/Earth attached to it, this is then your Star Ground Point for any other Ground/Earth wires you may need to have
Mactec54
