Ground Point - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Ground Point
  1. #21
    Dec 2003
    Default Re: Ground Point
    Installed many systems earth grounding the DC supplies common and have not had a problem, I set up a 1/4" tapped copper ground plate and take every earthed common to it.
    Together with equi-potential bonding.
    Per the PDF: The concept of Earth consists of one homogeneous mass that is electrically neutral, i.e.
    an equal number of negative and positive charges are distributed throughout the earth at any given time.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Al_The_Man View Post
    And how many Hobby user's can achieve this here on the Zone, you are talking a foreign language to a Hobby user, which only ends up with more problems, when they try and achieve a system that has an equi-patential bonded Ground system, what you did in the industry does not equal Hobby user, this is for dreamers only, you have been here long enough to know that
    Mactec54
  3. #23
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    There is nothing complicated actually. Only the problem is the way of explanation. It depends on the level of understanding and education background. Up to now the best description of "grounding" and protective earth belongs to Siemens in my opinion. I recommend to learn. Covers almost all aspects of earthing, Very detailed.
    Contains no expressions like "returning to source" or so.
  4. #24
    Jan 2005
    Quote Originally Posted by Algirdas View Post
    If you are talking about Ac Power Earth Ground circuits then that would be correct, you are not going to find source being used in an Ac circuit, understand what is being discussed would help you understand why the word source is used
    Mactec54
  5. #25
    Dec 2003
    Agree!
    Good comment!
Ground Point
Ground Point
