daisychaining 2 (or more) ATX computer PSU - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 52 of 52
Thread: daisychaining 2 (or more) ATX computer PSU
  1. #49
    May 2009
    canada
    Default Serial Connection of two power supply
    We use two S-150-24(+24Vdc, 6.5A), there are four terminals for the two
    power supply, Gnd_1,+24V_1, Gnd_2, +24V_2, then Use Gnd_1 as common
    ground, and CONNECTING +24V_1 with Gnd_2, and use +24V_2 as +48Vdc
    output.
    That will be a +48Vdc, 6.5A power supply by using two +24Vdc, 6.5A power
    supplys.
    We have used this +48Vdc,6.5A power supply to power up Dyn2 AC servo
    from www.dmm-tech.com
  2. #50
    Jun 2007
    This idea is good, my friend is an electronic engineer and he said all I have to do is isolate the DC circuit from earthing to the case and make sure all the power supplies have the same amp rating.
    I'm getting 48vdc and 14amps for 3 1200oz steppers from scrap pc parts!!!!
    God bless IBM!
  3. #51
    Registered xairflyer's Avatar
    Nov 2003
    Ireland
    Thanks for this thread very useful.
    Is there any problems with connecting two 400w supplies together (parallel) with one output of 12.2 and the other 12.5?
  4. #52
    Nov 2003
    Ireland
    To answer my own question now I have tried it, No!
