Version control for NC files
Results 1 to 7 of 7
Thread: Version control for NC files
    May 2009
    UK
    Default Version control for NC files
    Can anyone recommend a way to implement a version control system on NC files? Is this even something that exists?
    Our shop has 10 woodworking CNC routers. We mainly run routine jobs, but find that code modifications get made which cause us scrap and downtime. Some of the modifications are authorized and necessary, others are hacks to avoid doing the right thing (cutter comp and coord system changes, etc).
    For several reasons I can't make our code read-only at the machines.
    I'd like to investigate a version control system (from the software world - git, CVS, Subversion, etc), which would make changes easier to spot, authorise, and if necessary roll back.
    Any thoughts?
    Registered Kev Brook's Avatar
    Feb 2011
    United Kingdom
    Default Re: Version control for NC files
    Does your machine run on a Windows
    Read my blog for help and advice for beginners on CNC routers
    http://the-cnc.blogspot.co.uk/p/home.html?m=1
    May 2009
    UK
    Yes, they do... Servers and machine pcs are all windows...
    Feb 2011
    United Kingdom
    Quote Originally Posted by tomfish View Post
    You can put a windows password on it but then it would lock the whole machine. Just like your home computer
    Oct 2009
    Look into cimco NC base.
    Sent from my SM-N910V using Tapatalk
    May 2009
    UK
    Quote Originally Posted by Kev Brook View Post
    Hi, thanks, yeah this wouldn't work for us - the PC controller is needed while running the machines.
  7. #7
    May 2009
    UK
    Quote Originally Posted by ktmktmman View Post
    Thanks for this - this is the closest I've found so far.
    Anyone else using other solutions?
