- creatbot ed large printer (have an in with the supplier)
Creatbot D600Pro:
build volume 00x600x600mm
dual nozzles resolution .05 1.75 filamant dia
various nozzles diam--.3---1.0
filament compatibility pla,abs, carbon fiber, wood,nylon,pc, pteg,hips,pp
flexible,tpu,pva, peek etc
nozzle temp 350 degrees max,,bed temp 100 degreesmax, chamber 70 degrees max
drying temp 65 degrees
print speed 45mm/sec to 120mm/sec
automatic leveleling
auto shut off on power failure orfeed supply fail
220volt single phase
touch screen usb connect
supports STl,OBJ,AMF
size 915x845x1085 mm at 125kg weight
opsystem supported windoes 7,8,10 and Mac OS
- You may not post replies
- You may not edit your posts
Forum Rules
