- GeckoG540 + ZenBot4896 + ZhongHuaJiangSpindleMotor
I'm working on a project to use the Gecko G540 on a ZenBot4896 to control a Zhong Hua Jiang Spindle Motor with vCarve Pro via Mach 3..
I'm currently using Easel to output G-code files and loading them into Mach 3 for milling various substrates..
I'm able to program/reset the spindle motor VFD for testing after reading the manual..
I'm currently capable of programming the VFD to drive the spindle using the VFD keyboard arrows or Potentiometer dial..
I'd like to understand how to start, stop and vary the speed of the spindle automatically during milling operations..
I'd like to understand how to calibrate the machine and output simple large sculpture models to multiple milled sheets of foam for assembly..
Thanks for any help..
Project Photos..
https://photos.app.goo.gl/bd85db9w3fPNFNak6
Zenbot Model..
https://www.zenbotcnc.com/4896-4x8-cnc-router_p_34.html
VFD Manual..
https://photos.app.goo.gl/SEkr4Uv3aStUe8Cr7
Spindle Motor..
https://www.amazon.com/dp/B093FKF7YD
vCarve Pro
https://www.vectric.com/products/vcarve-pro
Easel to G-code
https://www.inventables.com/technologies/easel
Mach 3
https://www.machsupport.com/software/mach3/
My company website..
https://www.artdesigncode.net/
- You may not post replies
- You may not edit your posts
Forum Rules
