Need Help! drive issues!!!!!!
Results 1 to 1 of 1
Thread: drive issues!!!!!!
    Default drive issues!!!!!!
    Hello all!
    Preface; I have been a tool and die maker for 30 years, some cnc experience. I bought a bench top clone ZX7045 mill completed retrofit. It never ran code at g-code feed rate. Change the program feed and it would still run at the same rate. Running a sound logic BOB and Gecko G320 drives with reliance electric E712 servos. That system failed this spring and I replaced with a C76 UC300 from CNC4PC and switched to UCCNC control software.
    Fast fwd to where the machine stands now.
    I can get the UCCNC to run the axis calibrate program, but only one axis at a time. X calibrated with power to all three drives just fine. Y wouldn't calibrate at all. It would start to move and then jump eratically causing all drives to fault.
    I then disconnected power to x and z and the Y axis would then calibrate and I was able to adjust the dithering to a minimal amount.
    I then disconnected Y power and calibrated the z axis. This again has minimal dithering.
    After the previous statements I connected power to all three drives and the thing dithers heavily and jumps in all three axis! ( this is with the C34G320 hard enabled ) with the c34 soft enabled the fault light is on and there is no axis movement when typing a MDI line of code. UCCNC shows DRO movement, but not the machine.
    any input IS GREATLY APPRECIATED!
    If anyone is in Michigan with experience with this system, I would be open to have you look at it with me.
    Thanks for reading! Pic attached.
    Attached Thumbnails Attached Thumbnails drive issues!!!!!!-mill-zx7045-jpg
drive issues!!!!!!
drive issues!!!!!!
