What do you recommend for aMmaxnc 4 axis conversion to Gecko drives
Results 1 to 2 of 2
Thread: What do you recommend for aMmaxnc 4 axis conversion to Gecko drives
    Dec 2005
    Default What do you recommend for aMmaxnc 4 axis conversion to Gecko drives
    I have an old Maxnc 15CL that I've had for a long time. It's starting to get twitchy so I' considering changing over to everything Gecko. What is recommended as far as board, drives, etc. Remember I'll want to convert the 4th axis as well.
    Member phomann's Avatar
    Aug 2005
    Default Re: What do you recommend for aMmaxnc 4 axis conversion to Gecko drives
    I’d suggest the G540 4-axis controller. It should be fine for that size machine.
    https://www.homanndesigns.com/index....products_id=80
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com
