Usually issues like that are caused by a mismatch in units; like when the program is looking for inches but your machine is configured in mm. But that's more like a 25-to-1 ratio. It might be that you've set up your steps per unit wrong. Try commanding a move of one inch and see how far it goes; if it's significantly more than an inch, start over with the steps-per-unit calculations.
