Gecko G540 multiple estop wiring diagram request
Results 1 to 4 of 4
Thread: Gecko G540 multiple estop wiring diagram request
    Feb 2013
    uk
    Default Gecko G540 multiple estop wiring diagram request
    What would the circuit look like to wire two additional e-stops for a gecko g540 used in conjunction with Mach3? I have one on the controller box but need another two around the workshop. I’ve tried a few wiring variations out today but i’m flummoxed by this.
    Any links or diagrams most welcome.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Gecko G540 multiple estop wiring diagram request
    3 Normally Closed E-stops wired in series.
    UCCNC 2017 Screenset
    Feb 2013
    uk
    Quote Originally Posted by ger21 View Post
    Correct. However when we wired a test NC E-stop after the primary it not triggering Mach3?
    Mar 2003
    Shelby Township
    Then you wired it wrong.
    If you have 3 normally closed switches in series, activating any one of them will open the circuit and trigger the input.
