Using relay w/ G540 - 5v or 36v coil
Results 1 to 5 of 5
Thread: Using relay w/ G540 - 5v or 36v coil
    Aug 2009
    us
    Default Using relay w/ G540 - 5v or 36v coil
    New to electronics, and I want to use relays to turn on my router motor and dust collector. My power supply outputs 36v and 5v, wondering if there is any reason to get a relay with 5v coil or 36v coil?
    I'm looking at a T9AP1D52-36-01 relay, is this a good choice?
    Default Re: Using relay w/ G540 - 5v or 36v coil
    It looks to me like that relay would work. Stick with 36v if you have that power supply. Otherwise you end up like me with 4 different power supplies in my case.
    Aug 2009
    us
    Thanks for the reply.
    I actually have both 5v and 36v on the oem power supply of my Techno Davinci router, was just wondering if there was a reason to use one over the other,
    Member john-100's Avatar
    Mar 2007
    uk
    why not a 48V relay ?
    then you can use the G540's 48V supply
    what are you controlling with the relay ?
    John
    Aug 2009
    us
    I'm using 36v for the Gecko, could use that for the relays.
    Controlling router motor and dust collector
