- Gecko 201 Mounting Screws
How do you access (install) the Gecko 201 mounting screws located under the terminal block?
It does not seem possible to get a tool in there with the limited clearance.
Any advice would be appreciated.
Thanks.
Re: Gecko 201 Mounting Screws
The terminal blocks are on pins and can be lifted off. Just grab the edge of the block and lift straight up.
John
I looked at the underside and saw solder joints. Assumed it was one piece.
Thanks for the info. Very helpful indeed.
- You may not post replies
- You may not edit your posts
Forum Rules
