Unless I am reading it wrong, this drive is a standalone motor control that takes a STEP and DIRECTION signal. It looks like they call the STEP input "PWM" and DIRECTION input "F/R", which I assume is forward and reverse.
Because of that I do not think there is any way to run it with the G540. The G540 can output a VFD control voltage (0-10V) and work with a relay, but it does not output STEP and DIRECTION. You may want to run the G540 and this drive with a third party motion controller like the SmoothStepper or UC300. That will open up extra I/O to control that drive.
