Disabling single stepper on G540 drive
Results 1 to 1 of 1
Thread: Disabling single stepper on G540 drive
    localhost's Avatar
    Nov 2018
    Default Disabling single stepper on G540 drive
    Hello,
    I am using a Gecko G540 drive (with an Arduino-like PLC, Controllino) to drive 3 steppers. Is there any way to disable a single stepper out of the 3 and let the two others run normally ? (I need to disable one stepper so that it doesn't prevent another one from rotating).
    I have looked on this forum, and on the internet but with no success.
    Thank you all for your help.
    Best regards,
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Disabling single stepper on G540 drive
    So you need to deenergize the disabled motor? Then the answer is no, unless you modify your G540. It has a single /ENABLE input for all 4 motors.
    Dec 2013
    Turn off the power, disconnect the stepper motor from the controller, turn the power back on, and you should be good to go.
    Jim Dawson
    Sandy, Oregon, USA
