Need Help! diy parallel printer cable question
Results 1 to 5 of 5
Thread: diy parallel printer cable question
    Activation process muzzlitebeer's Avatar
    Sep 2018
    Default diy parallel printer cable question
    I can't find a male/male printer cable anywhere other than online. Trouble is, all my bits have arrived today and I want to get my Gecko up and running this weekend.
    I was lucky enough to be donated an old printer cable and bought a male DB25 assembly from Jaycar electronics. I've now successfully rewired the female end and checked continuity with a DMM.
    Here's my question; The Gecko manual describes pins 18-25 as "GND" but, although this printer cable has a jumper across pins 19 to 25, they're not actually 'grounded', just joined to each other. There is a conductor that connects the shell at one end to the shell at the other. Should pins 18-25 be grounded to the shell or am I right to go?
    Could someone please check their cable to see if there's continuity between these pins and the shell?
    Cheers in advance.
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: diy parallel printer cable question
    If the cable is shielded, solder the shield wire to the shell. If not, just leave the shell unconnected.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I believe that in an actual printer port, the pins and shell are tired to the same ground.
    UCCNC 2017 Screenset
    Member john-100's Avatar
    Mar 2007
    uk
    on a PC motherboard the printerport socket
    the metal shell & pins 18 to 25 are all connected together and
    via the ATX power supply black 0V wires to the mains supply earth / ground
    if you can only find a printer extension cable (f/m)
    you could of use a gender changer like this:-
    diy parallel printer cable question-gender-changer-male-male-25-way-spc19825
    https://cpc.farnell.com/multicomp/sp...xoCx1YQAvD_BwE
    to save changing the connector on your cable !
    some cheap printer cables don't have 25 wires inside
    so they connect terninals 18 to 25 together to use 1 wire instead of 8 !
    this is not a problem with the Gecko G540 or most breakout boards
    as long as a printerport ground pin (18 to 25) is connected to a G540 ground pin (18 to 25 )
    it will work
    as far as I remember
    the CNC4PC C10 breakout board is unusual
    pins 19 to 25 are all ground as expected
    but pin 18 is used to detect when the board connected to the PC printer port
    (or motion controller like the smooth stepper )
    John
    Sep 2018
    Thanks for the help guys.
    Cheers
