That would be correct. You could use the 72 volt power supply. You won't get the top speed out of those motors but if it is fast enough then it will be OK. Other that you could look for motors with 5.2mh or less inductance. 5.2 would put you at 72.27 volt motor. I would try the 72 volt supply and see how it goes.
John
