6.5w air solenoid directly to g540 without relay?
Results 1 to 5 of 5
Thread: 6.5w air solenoid directly to g540 without relay?
    Member QuinnSjoblom's Avatar
    Nov 2017
    bigfork
    Default 6.5w air solenoid directly to g540 without relay?
    setting up my mist coolant with g540, mach3. my air solenoid is rated at 6.5w (0.54a, 12v). g540 output can handle up to an amp right? so should be fine without a relay? or bad idea?
    Member phomann's Avatar
    Aug 2005
    Quote Originally Posted by QuinnSjoblom View Post
    Yes you should be fine to drive the solenoid directly. The G540 outputs also have the fly back diodes built in as well.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com
    Nov 2017
    bigfork
    Quote Originally Posted by phomann View Post
    Cheers
    Peter
    Excellent, thank you. That will clean things up nicely. One more question, if I ever add a second solenoid, is it 1 amp limit per g540 output, or 1 amp total for all outputs?
    Aug 2005
    Default Re: 6.5w air solenoid directly to g540 without relay?
    Yes it is 1A per output.
    Cheers
    Peter
    Dec 2003
    Another method if a VFD is used, is to operate the solenoid from a VFD output which can be either set to turn on/off by the At Zero or At Speed parameter.
    A manual SW can be introduced if over-ride is needed.
