nema17 / G540
Results 1 to 19 of 19
Thread: nema17 / G540
    May 2005
    us
    Default nema17 / G540
    I'm setting up a project with a G540.
    My power supply is ~50v @ 8 amps.
    These are the steppers I would like to use: Nema 17 2.1A Stepper Motor High Torque 92oz.in
    There inductance is: 3mH±20%(1KHz)
    When you run the numbers, the voltage come out to 55.4v which exceeds the capacity of my power supply and the 50v limit of the G540.
    What would be the effect if I used them anyway?
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: nema17 / G540
    If the 5.4V makes a noticeable difference
    you have either chosen the wrong motor or stepper driver
    (on a good day 3mH less 20% = 2.4mH which is ideal with your 50V power supply )
    how precise are you going to set the motor current ?
    2100 ohm resistors are available from the E96 range
    mouser.com
    Mouser No:
    660-MF1/4DCT52R2981D
    if buying the resistors locally restricts you to the E12 range
    1800 ohm & 390 ohm resistors in series will give you 2190 ohms
    (with resistors in series you only have one wire to soldered to each of the 9 pin plug terminals)
    John
    May 2005
    us
    Quote Originally Posted by john-100 View Post
    Yup. That's what I'm hoping to avoid.
    Definitely what I'm hoping to get.
    I thought I'd just series a couple of 1k's or stack a couple of 3k9's. But I'm open to suggestions. I have lots of resistors.
    Mar 2007
    uk
    Gecko drive recommend 5% resistors are used to set the motor current
    if you have a large number of 1K 5% resistors you may be able to find some close to 1K05
    that two in series will give you 2K1
    nema17 / G540-g540-resistors-series-parallel-plus-gc-02-a
    John
    May 2005
    us
    Sorry, I had in my head that the steppers were 2.0 amp. Oops.
    May 2005
    us
    I guess my original question should have been 'what is the effect of running a motor at less than the recommended Gecko voltage'?
    I assume there will be a loss of holding power. Will it be significant? Will there be other effects?
  7. #7
    Member awerby's Avatar
    Apr 2004
    If you give the motors less voltage, they won't run as fast. But 5.4v isn't too significant. You'd only lose torque if you gave them less current (than 2.1 amps). What are you trying to build, anyway?
  8. #8
    Mar 2007
    uk
    all other things being equal
    the stepper drivers supply voltage affects the maximum speed you can step the motor
    if your motor has a 1.42 ohm coil resistance then applying 3V DC will result in a current of 2.1A
    which is OK when the motor is still
    using a motor supply voltage several times the voltage on the motors data sheet
    has the advantage of forcing the current to build up to the desired current in a shorter time
    enabling you to step the motor faster but the stepper driver needs to limit the current to 2.1A
    on the other hand
    the motor current determines the motor torque
    so using a 50 V supply will slightly reduce the maximum speed you can step the motor
    and setting the current to 2A with two 1 K resistors will slightly reduce the torque
    John
  9. #9
    May 2005
    us
    That's what I wanted to hear. Reducing the voltage just slows things down proportionally. You still get rated power as long as your power supply has got the amps.
    It's going to be a mini-lathe based on a pair of Parker slides. I've built a couple of other machines using them and I absolutely love 'em.
    Thanks gents.
  10. #10
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Quote Originally Posted by doanwannapickle View Post
    That recommendation is the Maximum voltage. At a lower voltage, you'll have less top speed, but it should be a negligible difference.
    UCCNC 2017 Screenset
  11. #11
    if you order this NEMA 17 KL17H272-20-4A, it should be ok
    you need to set the current to 2A
    Applied Voltage: 32 x sqrt (4) = 64VDC
    Current Per Phase:2.0A
    Holding Torque: 9 Kg.cm (124 oz-in)
    Rated Voltage: 3.2V
    NO.of Phase: 2
    Step Angle: 1.8° ± 5%
    Resistance Per Phase: 1.6?± 10%
    Inductance Per Phase: 4.0mH± 20%
    Insulation Class: Class B
    Dielectric Strength: 100Mohm
    https://www.automationtechnologiesin...l17h272-20-4a/
  12. #12
    Apr 2013
    Sweden
    mouser.com
    Mouser No:
    John
    If he wants to be perfect and uses E12 series then it is better to use 2.2k in parallel with a 47k. That will give 2.10K, which is as good as he can get. There is no point in doing what you propose since it will result in only 10 Ohms below the standard value of 2.2k.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
  13. #13
    Mar 2007
    uk
    1800 + 270 would of been a better solution
    for members who have little practice soldering
    I still think its easier to have two resistors in series
    easy to insulate with a plastic sleeve
    nema17 / G540-g540-resistors-series-jpg
    nema17 / G540-g540-resistors-parallel-jpg
    the main thing to use the best solution for you
    john
  14. #14
    Apr 2013
    Sweden
    Why? That's still giving the wrong value since 30 Ohms are missing.
    2k2 parallel with 47k is 2102 Ohm (2101.6260162601626016260162601626 Ohms to be more precise) and that's DEFINITELY better than 2070 since the difference is only 2 Ohms. I have no idea how important it is, but really, why would 2070 Ohm be better than 2102 Ohm if you need 2100 Ohm? Connecting two resistors in parallel is just as easy as connecting two in series, so what is the benefit? Why would 1800 + 270 be better than a more exact value?
  15. #15
    Mar 2007
    uk
    duplicate post
  16. #16
    Mar 2007
    uk
    using resistors 5% tolerance resistors in series
    1800 + 270 would of been a better solution in the sense that its about 1.5% lower than the desired 2100 ohm
    instead of the 1800+390 posted in error in post 2 ( not sure what caused my error )
    as an alternative 1800 +330 would be 1.4% high
    from a practical point of view
    I expect some will find it easier to wire the resistors in series and that's why I posted that solution
    as I don't think you need to be accurate to the Nth degree setting the motor current
    although I admit I would use a single 2100 ohm E96 resistor
    John
  17. #17
    Apr 2013
    Sweden
    That's because people generally understand how to connect resistors in series AND calculate the new value but have no clue about how to calculate resistor values for parallel connections.
    John
    I would probably look in my boxes and take what I have, if I don't have a 2k1 then I'd use my calculator to get the right value. If I don't have a single resistor with the right value I'd use parallel or serial connected resistors to get the right value.
    ...but like I said, I have no idea how critical this is for the Gecko because I don't have that driver... Probably it doesn't really matter if you use 2k1 or 2k2 resistor.
  18. #18
    May 2005
    us
    Quote Originally Posted by A_Camera View Post
    Well, that was going to be my next question since the whole resistor thing is being wrung out. Just how close is close enough? Is it better to go high or low? What is the effect of each?
    I don't have a problem putting them together series or parallel or a combination thereof as long I can cram them in the shell.
    Backing up a bit, I'm now thinking of going with the motors suggested by Automationtech.
    Inductance Per Phase: 4.0mH± 20%.: This calcs out to 64v using the Gecko formula but it has now been pointed out that this is a max voltage and a lower voltage is just going to produce less rpm.
    Holding Torque: 9 Kg.cm (124 oz-in).: That's a lot of grunt in a small package.
    My screws have a 5mm pitch and the total travel is just a bit over 4" so I don't think I need a lot of speed but torque is good.
  19. #19
    Mar 2007
    uk
    with the Gecko G540 the motor current is 1A per 1000 ohms across pins 1 & 5 on the 9 pin plug
    up to 3500 ohms to set the current to the G540's maximum of 3.5A
    getting the resistors within 2 or 3% is not going to be a problem
    various possible ways of setting the G540's motor current
    nema17 / G540-g540-resistors-series-2-parallel-plus-gc
    one issue some users have is when they omit the 3K5 resistor
    because the G540 default current without a resistor is 3.5A
    the catch is without the resistor the G540 does not reduce the current when the drive is idle and not being stepped
    the result is the motor runs hotter
    one handy online calculator for 2 resistors in parallel can be found here :-
    Resistor calculator - compute the best resistors combination to obtain a given value
    with the calculator you can easily see the effect of using resistors with different tolerances
    10% restricts you to 12 possible values per decade (10 ,12 , 15 , 18 , 22 , 27, 33 , 47 , 56 , 68 )
    1% gives you 96 possible values per decade
    the new motors calculated 64V supply verses the G540's 50V limit can be a problem
    as the speed you can step the motor is going to be reduced by approximately 22%
    john
    PS
    a motor with 2.8mH 3.5A coils would be closer to the G540s ideal limit
    something like this
    https://www.automationtechnologiesin...23h2100-35-4a/
    then again bigger is not always better
    so splitting the difference
    a motor with coils having an inductance of 2.8 to 3 mH at 2.5A to 3A could be what you need to look for
    its a pity we don't have feed back from any Gecko G540 users
nema17 / G540
nema17 / G540
