bad cnc
Results 1 to 2 of 2
Thread: bad cnc
    Apr 2018
    Denmark
    Default bad cnc
    Hi
    I have had my hobby cnc for several years where it has run well. But now it has started to mill toolrun number 2 offset by the 1st (see bottom arrow)
    In addition, it makes a bow to an almost straight milling (top arrow)
    It is as if toolbar No. 2 when the milling iron has to run several laps to remove the material moves in my y axis.
    I'm driving Mach 3 and g540bad cnc-pis-jpg
    Anyone who has a bid?
    Sincerely
    Henrik
    Attached Thumbnails Attached Thumbnails bad cnc-pis-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: bad cnc
    It's probably a mechanical problem. Check to see if a coupler between the motor and leadscrew is coming loose on the axis that's misbehaving. If your machine uses rack-and-pinion drive, it could be a loose pinion gear.
bad cnc
bad cnc
