- G320X Connection help needed
Re: G320X Connection help needed
You need to seperate out the actual encoder connections which would be
2 A Red/BLK
3 B WHT/BLK
4 I Blue
5 +5V Red10 A Green
10 A Green
11 B Orange
12 I White
13 Encoder GND Black
while it does not specify the positive and negative connections of th encoder I would venture a guess that that 2,3,4 are the negative signals while 10,11,12 are positive. read the manual for the drive that will start to make some sense of the rest estop / enable circuit is strange on that drive though.
I realize many of those connections do not go to the drives.
Would I be better off to replace the encoders with some AMT units, that are documented?
is there no model # on the encoder? must be something there... does it have a millspec type connector?
The encoder is under a shield which did not look easily removeable. I assumed the whole motor and encoder was more or less sealed. I probably need to investigate that further.
I did contact the manufacturer of the motor for additional information, but did not realize the encoder was a separate component.
sometimes...sometimes not, what brand and model motor is it? dont just remove the encoder from the motor, you could cause a lot of issues that way.
Here's what is on the labels:
MCG 1500 North Front, New Ulm MN 56073
PH (507) 233-7000 FAX (507) 359-7827
Part No. 223-M4130 H50R10-0243
Torque, Cont. 50.00 oz-in
Current, Cont. 1.99 AMPS
I tracked down MCG as having been acquired by Ametek.
They sent me the data sheet attached above, which has nothing on the encoders.
The Techno docs do not have any model numbers for the encoders, just the pinouts above.
I think I need to do some more investigating
sorry never looked at the spec sheet, you should be able to remove that encoder of the back of the motor and not cause problems. if its a dynapar encoder you could probably look at the document link below and determine what the connections should be.
https://www.dynapar.com/uploadedFile...S_702034_3.pdf
OK, here's what I have. No label visible. Might be on the bottom.
Does this look like a Dynapar? I'll take it off if I really need to.
not from the ones that I know they usually do not have plastic frame parts. maybe you are better off trying to find out how they connect to your current servo drives? see if you can find a manual for your existing servo drives that shows how the encoders connect.
No info available. All I got was minimal data sheet on the motors.
No hardware info, drive manufacturer was bought out years ago.
- You may not post replies
- You may not edit your posts
Forum Rules
