Nice to see you on this board.
The servo drive system using a Gecko drive is only closed loop back to the gecko drive only. There is no loop back to the software on the PC. If the Gecko drive gets behind processing steps because of a heavy cut or too fast of feed the drive will fault but the software will not know this has happened. It is the next best thing to a complete closed loop system for a lot less money.
