- Buying a laser cutter from G Weike or Perfect Laser; what are "DDU fees by LCL"?
Activation process
I'm close to pulling the trigger on a 600mm X 900mm 120W laser cutter directly from either G Weike or Perfect Laser, shipping to the USA. Does anyone know which might be better? They seem to be fairly similar machines.
One big difference between the two quotes is the G Weike quote has a "DDU fees by LCL" for $1200, which I thought was the shipping cost to get the laser from China to the NYC port.
But the Perfect Laser quote has a line "Sea Shipping Cost To New York Port" for $180, which is much cheaper.
Does anyone know what "DDU fees by LCL" might be, if not just the shipping cost to port? I've asked G Weike and expect them to reply soon, but wanted to also check with the community here.
Thanks.
Activation process
Re: Buying a laser cutter from G Weike or Perfect Laser; what are "DDU fees by LCL"?
OK I think I got to the bottom of this, in case anyone else is confused: this line item includes cost of shipping the laser across the ocean to the port, plus cost to ship by truck from the port to my house, plus various custom fees, but NOT including inspection fees and the tariff.
- You may not post replies
- You may not edit your posts
Forum Rules
