- How to adjust corner power: RDworksV8 software running a G.Weike laser machine
Hi All,
I’m calibrating a G. Weike laser cutter running with RDworksV8 software. It’s going well so far, however, I’m cutting thin material and need to reduce the power of the laser around corners and tight archs to avoid the slight burn out that is occurring.
I’ve search manuals and forums and just cant find where this setting lives. Any help would be greatly appreciated!
-Josh
EDIT: Figured it out...super simple: Min Power corresponds to corner power and Max Power is power on a straight line.
Reason: Solution discovered
- You may not post replies
- You may not edit your posts
Forum Rules
