CRC programing with an old Fanuc 11M controller
Results 1 to 6 of 6
Thread: CRC programing with an old Fanuc 11M controller
    Feb 2005
    Default CRC programing with an old Fanuc 11M controller
    I've been away from CNC machine for about 4 years and the show I work at just got a CNC mill. The problem I am having is that I can't get the cutter radius compensation to initiate. The machine has a Fanuc 11M controller. I'm not sure if I am inputting the radius offset in the correct location. Do I just input it in the same offset pages that I use for tool length compensation?
    EG. using tool 27 I'm using TLO H27 and CRC D77. H27 being -10.000" and D77 being 1.000" for a 2" dia. tool. Our machine has offsets 1 through 99 but Im not sure if there is a separate offset page for diameter offsets. Can anyone help me out?
    Dec 2003
    I am not a machine operator but I believe the D offset is picked up by the G41 or G42. or are you already using this?
    What was wrong with the servo's, by the way?
    Al
    Feb 2005
    I got the CRC figured out. Thanks for replying Al. One of the boards in the back was faulty. We're running the y axis off the A axis board until we can get a new board or this one repaired.
    May 2004
    You should only have to enter the radius value into the offset page (after the R or T). It could be possible that the parameter for tool comp is not turn on. I think it is Parameter 907.6.
    May 2004
    Private Message me for a complete list.
    Aug 2016
    Quote Originally Posted by bbailey View Post
    Do u have a list for the fanuc 11m. For tool comp.thanks
