DXF to G-Code
Results 1 to 6 of 6
Thread: DXF to G-Code
    Oct 2003
    Software For Metalworking
    http://closetolerancesoftware.com
    Apr 2009
    canada
    Default gcode
    i find software for convert dxf to g-code
    Member hasanqo's Avatar
    Dec 2019
    Default Re: gcode
    what is the name plz ??
    Member awerby's Avatar
    Apr 2004
    Default Re: DXF to G-Code
    What you need is a CAM program, not a "converter". There are too many variables that go into a G-code program to simply assume you can just change the one file type into another. You need to specify the correct tool and how it relates to the part, tell the machine how fast to run and the spindle how fast to spin, post-process the file to work on your particular machine, etc. Running random generic G-code is usually a recipe for disaster.
    May 2005
    canada
    I have food.
    Give me the recipe.
    Seems logical :
    Anyone who says "It only goes together one way" has no imagination.
DXF to G-Code
DXF to G-Code
