Why when I export a gcode from my laptop it exports it incorrectly using inkscape
Why when I export a gcode from my laptop using inkscape it exports it incorrectly and when I export it from another laptop with the same exact method it exports it correctly
Here are the codes in question>
The incorrect code:
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
#8 = 0 (Z axis offset)
#6 = 0 (X axis offset)
#7 = 0 (Y axis offset)
#10 = 1 (XY Scale factor)
#11 = 1 (Z Scale factor)
#20 = 100.000000 (Feed definition)
#21 = 400.000000 (Feed definition)
(Start cutting path id: path5540)
(Change tool to Cylindrical cutter)
(Header)
M3
(Header end.)
(Start cutting path id: path6)
Re: Why when I export a gcode from my laptop it exports it incorrectly using inkscape
I'm not an Inkscape user. But if exporting the same file from different laptops gives different results, then its likely that the program settings/configuration are different on each laptop. So you will have to check/change those to make them the same.
