Convert g2 g3 r to g2 g3 ijk
Results 1 to 9 of 9
Thread: Convert g2 g3 r to g2 g3 ijk
    Mar 2007
    romania
    Default Convert g2 g3 r to g2 g3 ijk
    Hi, what is the formula to convert a G2 or G3 command with R option to IJK option? my CNC board only accepts IJK version But some CAM software only output the R version. I am sure that this was talked before, but i cant find almost anything.
    Thank you,
    Dan
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Convert g2 g3 r to g2 g3 ijk
    hy if you can't fix your postprocessor, i can help you
    ijk are more or less control specific ( try i for x axis, and k for z); represents the signed distance between center and start-point; pls check also attached
    also tried to sent you a message / kindly
    Attached Thumbnails Attached Thumbnails Convert g2 g3 r to g2 g3 ijk-untitled-png
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Mar 2007
    romania
    deadlykitten, i dont have a lathe, i have a router.
    I need to transform g2 xyr into g2 xyij.
    Jun 2015
    Antarctica
    pls, active your private message
    also, you may find attached generic ijk for milling
    Jun 2018
    on my feet
    some cnc editors have the options of converting files , ncplot for one does
    Mar 2007
    romania
    metalmayhem, thank you for reply, but i need the theory to implement it in my software.
    deadlykitten, i have checked all my settings, private messaging is activated, i can receive messages from everyone. I know what IJK are, i want to calculate them only from start point, end point and radius. User Kiwi had made a small piece of software that calculate exactly that, but he is not active anymore...
  7. #7
    Mar 2007
    romania
    This is the software, i need the theory behind
    Attached Files Attached Files
  8. #8
    Jun 2015
    Antarctica
    pls, try to send me a message
  9. #9
    Jun 2015
    Antarctica
    hy, i can't reply pls, if you wish, leave an email
