hy i can develop custom software
if you wish, show your curent workflow, then what you wish to change, so to have a clue / kindly
I have a fixture assigned to g56, and that fixture engraves 9 individual plates at a time. Each with a unique design.
Currently, to create toolpaths I import whatever 9 designs into the same folder (dxf). I then open my cam program (vetric cut2d), and import using one of their tools which atomatically spaces the dxf's out with the correct spacing according to my fixture. Each dxf file has the same size rectangle around the design to allow this behavior. I then select the appropriate geometry, create a toolpath, then export.
Is there a better way I could be doing this? It seems like I should be able to generate gcode for each file individually and somehow combine them into a single file with offset instructions. I simply don't know what to search however. Can someone give me a lead?
Thanks in advance for whatever insight you may be able to give!
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
You can't get it easier than you are doing it, when you split it up into separate operations / programs you can use a different work offset for each part, you could also in Cut2D, just select one part at a time and have each part with a separate program, so once you lay it out, then just do each operation separate
Mactec54
