hy you need a corection inside the program, thus not an offset, that will adjust position among circumfereence
this can be added as a variable inside each position block of your code, and you can control it from your system variable input panel, thus there will be no need to recreate the code outside the machine, then reload/reselect, but simple panel operation
i can help with a simple application that will input the corection variable automaticall inside your program file; after that, you will need to build a table, that will help converting circumference corection to C axis degrees, or whatever is needed for your program to work properly / kindly
