What machine? Controller?
in y post processor i added a line of code, M73, and it starts my vac pump. but then the file stops. is there an extension or a prefax i'm supposed to add as well? tia
- Need help with g code for fire control pocket on AR15 lower reciver, have G code.
- Can I use G-code/M-code to control external device by Weihong controller?
- Program to Convert Mill g code To Laser g code - CMTL
- mach3 crashing with run of code/drilling holes through table with other code
- Newbie- corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
Jim Dawson
Sandy, Oregon, USA
atc, syntec controller
I can't find any reference to M73 in the syntec manual I could find on line. Do you have a link to your manual?
Jim Dawson
Sandy, Oregon, USA
