you will see it changes as i go with it; purpose is to be fast, and process common technical drawings just like a paper shredding machine; if you have some ideas, just say
as for swiss, i only touched a citizen, dual spindle, max dia 12 ... it was a chalenge, because until than, i was not used to small tooling, so i simply needed to learn to feel that machine; it requires much more atention, especially those really tiny boring tools, or alignment of long thin drills i always got my hands and tshirt full of oil, since it did not use coolant ... onestly, i don't like it as much
mistakes are .... a god teacher onestly, because of them, i have started to look into safety methods; there is some progress
at this moment, when it comes to lathes, i no longer align them after a crash, thus i started to align only necesary tooling even on lathes with messed up geometry; a good example is drilling o40*150mm depth, on a turret tilted in z a few 10s, x off center a few mm, and tilted spindle ... i no longer worry
haha, you have to make up your mind it's not easy to learn what you hate ... go with millingI would like to learn Swiss lathes. I hate them!
