Need Help! GCode Junkies Please Educate Me / Help Me Find The Issue! GRBL "Bitsetter"
Results 1 to 6 of 6
Thread: GCode Junkies Please Educate Me / Help Me Find The Issue! GRBL "Bitsetter"
    Member BJGoldstein's Avatar
    Oct 2021
    Question GCode Junkies Please Educate Me / Help Me Find The Issue! GRBL "Bitsetter"
    Hello! I'll try to keep my explanation as short as possible. I'm learning, playing and have a small GRBL machine. I was able to steal / modify / make a macro that successfully facilitates a bit change at a fixed location. Essentially, the macro touches, I change the bit, touch again and Z Zero is shifted accordingly. It works fine. Again, I found some examples and refined it for my setup.
    Now, I want to explore combining GCODE files that use different tools; so I can basically run one file and the bit change occurs right in the process.
    Anyway! I was working on a project today and tried all of this out. It generally works, except for the fact that for some reason the Z offset change is not working correctly now, within the file. When it starts machining after the bit change, it wants to dive way, way too deep. The file below was very long and I shortened the boring machining sections and you'll see *** notes in there. The important stuff is the beginning, tool change and final machining.
    Can anyone see any issues that I might be able to correct? Would be highly appreciated!! Thanks!
    -Brian
    T1
    G17
    G21
    G90
    G0Z20.320
    G0X0.000Y0.000
    S16000M3
    G0X18.411Y86.089Z5.080
    G1Z-1.191F635.0
    G1X16.864Y85.009F1524.0
    *** (BEFORE AND AFTER THIS NOTE IS JUST MACHINING - M5 IS WHERE MY TOOL CHANGE BEGINS
    G1X32.742Y21.228
    G1X31.839Y21.115
    G1X30.964Y20.833
    G1X30.174Y20.381
    G1X29.469Y19.817
    G1X28.848Y19.139
    G1X28.396Y18.349
    G1X28.086Y17.502
    G1X27.916Y16.599
    G1Y15.696
    G1X28.086Y14.793
    G1X28.396Y13.946
    G0Z5.080
    M5
    %wait
    %SAFE_HEIGHT = -5
    %TOOL_PROBE_X = -34
    %TOOL_PROBE_Y = -310
    %TOOL_PROBE_Z = -10
    %PROBE_DISTANCE = 110
    %PROBE_FEEDRATE = 300
    %RETRACTION_DISTANCE = 10
    %X0=posx, Y0=posy, Z0=posz
    %WCS = modal.wcs
    %PLANE = modal.plane
    %UNITS = modal.units
    %DISTANCE = modal.distance
    %FEEDRATE = modal.feedrate
    %SPINDLE = modal.spindle
    %COOLANT = modal.coolant
    M5
    G90
    G21
    G53 Z[SAFE_HEIGHT]
    G53 X[TOOL_PROBE_X] Y[TOOL_PROBE_Y]
    G53 Z[TOOL_PROBE_Z]
    %wait
    M0
    G91
    G38.2 Z-[PROBE_DISTANCE] F[PROBE_FEEDRATE]
    G0 Z2
    G38.2 Z-5 F45
    G90
    %ORIGINAL_TOOL = posz ;store current work position
    G4 P0.5
    G91
    G0 Z[RETRACTION_DISTANCE]
    G90
    G53 Z[SAFE_HEIGHT]
    %wait
    M0
    %wait
    G53 Z[TOOL_PROBE_Z]
    G91
    G0 Z2
    G38.2 Z-25 F45
    G90
    G4 P0.25
    G10 L20 Z[ORIGINAL_TOOL]
    G4 P0.25
    G91
    G90
    G53 Z[SAFE_HEIGHT]
    %wait
    M0
    G0 X[X0] Y[Y0]
    G0 Z[Z0]
    [WCS] [PLANE] [UNITS] [DISTANCE] [FEEDRATE] [SPINDLE] [COOLANT]
    ***(NEXT MACHINING BEGINS HERE, AFTER TOOL CHANGE)
    T1
    G17
    G21
    G90
    G0Z20.320
    G0X0.000Y0.000
    S16000M3
    G0X33.300Y15.163Z5.080
    G1Z0.000F254.0
    G1X33.516Y15.265Z-0.006
    G1X33.723Y15.438Z-0.013
    G1X33.888Y15.661Z-0.020
    G1X33.989Y15.909Z-0.027
    (MACHINING CONTINUES)
    Member machinehop5's Avatar
    Aug 2009
    Default Re: GCode Junkies Please Educate Me / Help Me Find The Issue! GRBL "Bitsetter"
    ...G43 and G49 codes may need to added to your postprocessor.
    T1
    G17
    G21
    G90
    ...insert G43 Hxx here (xx= tool offset number of your choice) or somewhere before the 1st Z axis move
    G0Z20.320
    G0X0.000Y0.000
    S16000M3
    G1Z-1.191F635.0
    ...G49 H00 to cancel Tool Length Comp before Tool change
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by machinehop5 View Post
    T1
    G17
    G21
    G90
    G0Z20.320
    G0X0.000Y0.000
    S16000M3
    G1Z-1.191F635.0
    No you should never have a need to cancel Tool length offset, by using a G49, if each tool is setup in the Tool offset control Page, you have no reason to cancel it.
    Mactec54
    Aug 2009
    ...so, why is there a G49 Code if you never need it? If, you do not cancel TLC at the end of each Tool you are setting yourself or the next person to a possible crash due to an Active Offset.
    Oct 2021
    To clarify, where would the tool offset information come from? Keep in mind I have a hobby machine so when I insert bits the position is arbitrary. Obviously the tool length is only determined by using the touch probe or manually zeroing the tool.
    Jan 2005
    There are a lot of redundant codes that are not needed today, with modern controls, and with hobby controls also.
    In 50 years I have never used a G49 or seen anyone have a crash from not using it, it is not needed. back in the day when everything was hand coded, it would of been used then, as hand coding was always full of mistakes. this would of helped, maybe to save a crash. today it is not needed. a lot of controls have default codes and some may still have the G49 as one of the defaults, in this case it would be redundant to have it in you program.
    Once a tool offset is used and another tool is called with it's offset, there is nothing left, of the previous tool offset, there can never be a crash, because of the previous Tools offset not being canceled
    In this uses case he is resetting the Tool offset after each operation so there is no chance of a crash from not have a G49
    Mactec54
