IF and GOTO gcode statements Syntec controller "syntax error"
Results 1 to 5 of 5
Thread: IF and GOTO gcode statements Syntec controller "syntax error"
    Default IF and GOTO gcode statements Syntec controller "syntax error"
    Hi, wondering if anyone can help with my Syntec FC60WA controller (same as Syntec 6MB)
    If I try and do an IF statement I get a syntax error no matter what I try.
    The reasoning for the IF statement in my code is I want to not turn spindle on for a particular tool. My post processor doesn't allow condition loops (Vetric Aspire) so I'm trying to handle it in gcode.
    So my code would be something like this
    Code:
    #100 = 1 (1 is the tool number)
    N10 M06
    N20 T1
    IF [#100EQ1]GOTO40
    N30 M3 S8000
    N40...
    N50..
    But it throws a syntax error for the line containing the IF loop. If I remove the IF loop and have the GOTO only, it works without error. Can anyone help? Maybe there is another way to do this?
    Default Re: IF and GOTO gcode statements Syntec controller "syntax error"
    I have received an email from Syntec they say I need to use a macro, so I am looking into that now.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Quote Originally Posted by jabtronic View Post
    Code:
    N10 M06
    N20 T1
    IF [#100EQ1]GOTO40
    N30 M3 S8000
    N40...
    N50..
    Try using letter O instead of number zero in GOTO
    Sometimes, a space may be needed between addresses
    ie. #100 EQ 1 verses #100EQ1
    What the Syntec guy said in his email was that I can do this using "macro" instead of your standard ISO gcode, to me it appears to be similar code but the main exception is there needs to be %@MACRO header line at the beginning of the file, and every line of code needs to end with ;
    He gave an example:
    Code:
    %@MACRO
    #100 = 1;
    IF #100 = 1 THEN
       GOTO 200;
    END_IF;
    M30;
    I did a quick test and it appears to work, I will need to rewrite the post processor to format the file the way that is is required.
    Jan 2005
    I have found that on some controls I need to use brackets around the variable number.
    IF[[#100]EQ1]GOTO40
    Try that to see.
