Hi I generated a g-code for my drilling work but ran to this error in mach3
"R Less Than Z in Cycle in XY Plane"
and i don't have a clue
this is parts of the g-code
G90 G94 G91.1 G40 G49 G17
G21
G0 Z15.00
M3
G4 P4.0
G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0
X0.67 Y0.53
X0.88 Y1.12
X0.80 Y1.70
X1.41 Y2.16
X1.98 Y2.11
X2.38 Y1.62
X2.16 Y1.04
X2.75 Y1.04
X3.36 Y1.26
NOTE: When i change r to a bigger number than z instead of going down and drill and going up it goes up and moves in down
- Need Help!- Acramatic 2100 canned cycle on G19 plane
- Need Help!- "R less than z in cycle in xy plane" and I have no clue
- Problem- Drill Cycle Rapid Plane B769
- Need Help!- Drill Cycle Pecks from Rapid Plane
- Need Help!- Heidenhain CYCLE 19 Work Plane Tilt
Anyone?
Your position when the drill cycle is called is Z15.0 and the holes goes to Z0.0, if you call a retracion at R-6.00 its makes no sense cause this position is under your start position and even under the bottom of your holes
What is your holes Z top and Z bottom ?
I don't know what G91.1 is doing ??
Try this;
G90 G0 Z15.
G98 G81 X0. Y0. R6. Z0. F----
X--- Y----
X--- Y----
...R is the reference plane and Z is drill depth. Q is peck distances
N87 T5
N88 S2200 M03
N89 G00 G90 G54 X-146.05 Y-6.35
N90 G43 H5 Z2.54 M08
N91 G83 G98 X-146.05 Y-6.35 Z-15.504 R2.54 Q2.553 F447.04
N92 X-113.594
N93 X-81.139
N101 M09
N102 M05
N103 G53 Z0.
N104 G53 X0. Y0.
N105 M01
my problem is that if z axis is vertical and when negative goes up how can i drill with this g-code? it just doesn't makes sense
I think you misunderstand how drill cycles works :
there is 3 key z position in the cycle :
1) the Z position when you call the cycle
2) the Z called during the Gxx command of the cycle, which is the depth
3) the R which is the retraction position, the position you will go back before doing a new cycle.
All this can be absolute (G90) or relative (G91) with respect to the initial point (1)
this could be a correct example of your code :
G21
G0 Z2.00
M3
G4 P4.0
G98 G81 X0.00 Y0.00 R2.0 Z-5.00 F1000.0
X0.67 Y0.53
X0.88 Y1.12
X0.80 Y1.70
X1.41 Y2.16
X1.98 Y2.11
X2.38 Y1.62
X2.16 Y1.04
X2.75 Y1.04
X3.36 Y1.26
You say that your Zup is negative.... then your programming is $hit
G21
G0 Z15.00 ....this is initial level must be higher than R
M3
G4 P4.0
G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0.... R must be higher than Z
M98 is to return to R, M99 is to return to initial level at the end of each cycle
Get your machine to be correct... ie all Zs above the part are negative or positive.... Not mixed, as you have.
To work out axes, normally, up thru the spindle is Z+, the X is the longest remaining, last is Y. Positive direction is as seen from the operators position. I did say normally,
You can't drill anything with your code like that
G21
G0 Z15.00 ( Z axis is above the part by 15mm )
M3
G4 P4.0
G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0 ( Z0.0=the top of your part so your hole depth is 0.0 deep )
G81G98X0Y0Z-6 R15F1000. ( Now the R value only needs to be enough to clear your work so normally this would be around 3mm to 4 mm )
your Feed rate also is way to high also so start for a lower feed rate
G81G98X0Y0Z-6.0R4.F100.
X0.67 Y0.53
X0.88 Y1.12
X0.80 Y1.70
X1.41 Y2.16
X1.98 Y2.11
X2.38 Y1.62
X2.16 Y1.04
X2.75 Y1.04
X3.36 Y1.26
Mactec54
