Fanuc G92
Results 1 to 2 of 2
Thread: Fanuc G92
    Mar 2006
    Default Fanuc G92
    Why doesn't this G92 not work? Fanuc Series 2iTB controller.
    I'm thinking a thread parameter change.
    it gets here
    G0 G54 X3.071 Z.2 M8
    Then it just goes home.
    O0001
    (PROGRAM NAME - BOX)
    (DATE=DD-MM-YY - 21-0ZONTAL\C1-120 CARRIER\CI)
    (NC FILE - R:\OPER HORIZONTAL\C1-120-61203 DF SCALLOPE)
    (MATERIAL - STEEL INCH - 1030 - 200 BHN)
    G20
    (TOOL - 3 OFFSET - 3)
    (OD THREAD RIGHT INSERT - NONE)
    G0 T0303
    G18
    G97 S450 M03
    G92 X2.8571 Z-1.6 F.125
    X2.8449
    X2.834
    X2.8241
    X2.8149
    X2.8062
    X2.798
    X2.7903
    X2.7829
    X2.7758
    X2.769
    X2.769
    G0 X3.071
    M9
    G28 U0. W0. M05
    T0300
    M30
    Default Re: Fanuc G92
    You have three types A,B,C for lathe @Fanuc.
    This Gcode can be different, based on which type your controller is set.
    It can be changed in PLC
Fanuc G92
Fanuc G92
