G-Code Help: Radius to Radius Tangent Points (in X,Y)
G-Code Toolpath: __oOo___ = Here’s a rudimentary depiction of a line (G01), a .195r radius fillet (G03), .313r larger radius (G02), and another .195r radius fillet (G03) connecting tangent to the line (G01) for G-Coding inside of a pocket at .500" z-depth and I’m using a 3/8 end mill. This is the only part I couldn't figure out nor find math websites to calculate the chords.
The center of the .313r lays on the same line that the .195r fillets share their tangent points with.
Direction: From left to right (G41) climb mill
PATH: The tool path follows the line (G01), follows the smaller .195r counterclockwise (G03) starting at the tangent point with the line
The .313r shares a point of tangency with the .195r; the toolpath then runs clockwise (G02) until meeting the second .195r to once again share a tangent point returning to the last tangent point with the line (G01).
Need help calculating the (x,y) points of tangency in order to G-code aluminum.
