g76 thread cycle for dummies 20i fanuc - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Thread: g76 thread cycle for dummies 20i fanuc
  1. #41
    Sep 2010
    India
    can i have a copy of your cheat sheet go2sid@gmail.com
  2. #42
    Nov 2014
    Default Re: g76 thread cycle for dummies 20i fanuc
    Your post is dated 2003. If it is still available I would like a copy of your cheat sheet on canned cycles, particularly G76.
    Thank you,
    MIchael
  3. #43
    Oct 2011
    u.k
    May I have a full copy of your cheat sheets please, kobra_wizzard@yahoo.co.uk...thanks[,QUOTE=dcrace;326166]G0X__Z__(approach Point
    G76P_Q_R_
    G76X_Z_R_P_Q_F_
    First G76 Line Info
    G76 P010060 Q00500 R.001 (finish Passes)
    G76 P010060 Q00500 R.001 (chamfer Amount At End Of Thread)
    G76 P010060 Q00500 R.001 (tool Tip Angle)
    G76 P010060 Q0050 R.001 (minimum Depth Of Cut - Radial Value)
    G76 P010060 Q0050 R.001 (finishing Pass Depth)
    Second G76 Line Info
    G76 X Z R P Q F (minor Dia Of Male)(major Dia Of Female)
    G76 X Z R P Q F (end Point Z)
    G76 X Z R P Q F (radial Diff. Of Tapered Thread)
    G76 X Z R P Q F (height Of Thread - Radial Value)
    G76 X Z R P Q F (first Depth Of Cut - Radial Value)
    G76 X Z R P Q F (feedrate / Pitch)
    ***R Value Can Be Omitted If Cutting A Straight Thread***
    EXAMPLE CODE FOR 1/2-13 THREAD, WOULD BE AS FOLLOWS:
    (TURN ON SPINDLE, CALL UP TOOL, TURN ON COOLANT HERE)
    G0X.6Z.2
    G76P020060Q0050R.0005
    G76G76X.404Z1.0P0100Q0472F.0769
    This is part of a "cheat sheet" of lathe canned cycles I made up to help train new setup people. If anyone is interested, I can e-mail it to you in excel format.[/QUOTE]
  4. #44
    Feb 2015
    Quote Originally Posted by kobra_wizzard View Post
    G76P_Q_R_
    G76X_Z_R_P_Q_F_
    First G76 Line Info
    G0X.6Z.2
    [/QUOTE]
    Could I get a copy of your "cheat sheet"
    Thanks,
    daveh@prodind.com
  5. #45
    Feb 2006
    india
    For detailed information on threading, G32. G34, G76 and G92, may have a look at this.
