dcrace
I would also like a copy of the canned cycle cheat sheat. Thanks for taking the time to do this.
daleh@ntin.net
dcrace
daleh@ntin.net
Please e-mail me a copy oy your "cheat sheet" of lathe canned cycles I made up to help train new setup people. If anyone is interested, I can e-mail it to you in excel format.[/QUOTE]
tate0663@yahoo.ie
I would like a copy oy your "cheat sheet".
stmeng@hotmail.com
thank you.
Can you please send me a copy of the cheat sheet.
fatcityfab@yahoo.com
I'm late to the party. This cheet sheet has a couple more details somebody might need.
'*******TWO LINE FANUC G76 INSTRUCTIONS*********************
'NOTE: Use G0,G1 to position machine at start of thread(Z) and retract height(X) before G76 lines.
' Important: X position determines ID or OD threads
'EXAMPLE G76 LINE 1 FOR 1/2" ROD 20 TPI
'G76 P011060 Q50 R10
'first two digits after P number of finish cut passes
'second two digits after P number of leads to pull out/10, 10 is 1 lead
'third two digits after P is tool tip angle, tool will infeed at 1/2 this angle
'Q is minimum DOC cut in tenths, example 50= .0050 depth radius
'R is DOC finish passes in tenths
'S is optional spindle speed, spindle must be running with an earlier M3 M4 code
'EXAMPLE G76 line two 1/2" rod 20 TPI .5" long 1 thou taper (Z 0 at start of thread)
'G76 Z-.5 X.4567 P433 Q100 F.05 R.001
'Z is end of thread Z value
'X is final diameter of thread value; minor dia. on O.D., major dia. on I.D. (LH) threads
'P is thread height in tenths, 433 is .0433 high, generally COS(infeed angle)*1/thread pitch
'Q is depth of cut for first cut in tenths
'F is feed per thread, 1/LEAD for US
'R is for tapered threading difference in X from start to finish in Z
send me a copy too of excel spreadsheet G76 MY E-MAIL IS carlos3z@sbcglobal.net
On the second G76 line, the 'Q' is related to the first depth of cut. When I use Q0050 which equates to .005/side, my internal thread on the first cut is moving to .013/per side. I am programming a Fanuc O-T on a Yang ML-55A lathe. Any suggestions as to why this is happening? Below is my code for a 1 1/2-6 internal thread:
(Minor diameter is bored to 1.34)
G0X1.1Z2.0
Z0.5M8
G76P020060Q0030R0.001
G76X1.5Z-2.2P820Q0030F0.1666
Also, I would like a copy of your cheat sheet. Thank you for your help.
soul_coughing03@yahoo.com
hi, for more info about G76 on fanuc cnc controls see my cnc blog post about G76 threading cycle CNC Canned Cycle G76 Threading Cycle for Fanuc CNC Machine Control. The cnc blog also has other cnc programming examples as well.
CNC Manual - Read & Download CNC Machine Manuals without Limits on any device
http://cncmanual.com/
Im new to this site, I just started work on CNC programming on Fanuc controllers.Its all new to me and its pretty cool stuff.Thanks for the explanation of the lines in the threading canned cycle. If you could send a copy of the cheat sheet id appreciate it, its a steep learning curve for me!Any recommendations of books to reference would be cool aswell, i have a copy of the cnc programming handbook that seems pretty good. my email is jimmipage@hotmail.com for thre cheat sheet.cheers for your help
Please e-mail me a copy oy your cheat sheet...
ifet.bukva@bredband.net
hi, would love a copy of your canned cycle for idiots karlbart@fairpoint.net
Although the thread is old but I have something to say...
The line
G76 P010060 Q00500 R.001 (tool Tip Angle)
in fanuc control manual it is stated as flank angle.
this value helps us to control the thread infeed angle for every pass.
The following indeef angles can be used as infeed angles with G76 fanuc threading cycle. 80, 60, 55, 30, 29, 00
For more info you might read Controlling Threading Infeed Angle with Fanuc G76 Threading Cycle
Helman Jr.
http://www.HelmanCNC.com
i like the way you detailed the explanation. i think it will help me well.
thanks
Like the way you set up heat sheets , have new puma and am needing to train some helpers could you email me your cheat sheets.. Thank you Brad Dallas
brad_dlls@yahoo.com
thanks for your posting.
Would it be possible for you to forward your spreadsheet of g76 setups?
Thanks in advance
Tim
Hey dgrace, you still have your cheat sheets? If so, can you send one here? quasifun@yahoo.com Thanks a ton.
If you still have your cheat sheet available, Id appreciate a copy!
skopras@yahoo.com
Thanks!
