Need Help! How to run engraving program at different depth
Results 1 to 3 of 3
Thread: How to run engraving program at different depth
    Feb 2017
    Default How to run engraving program at different depth
    I am running a 600 line engraving program on a Haas, need to run again at a different depth. Have been changing tool length comp, but loosing too much time.
    Member lucaswalker's Avatar
    Sep 2018
    Default re: How to run engraving program at different depth
    Add G92 Z-10 (Or Z-Whatever you need)
    It should shift the Z coordinates and run all the nc accordingly
    Make sure however that all your rapid moves are still above material, or at least inside the pocket you already performed.
    Feb 2017
    Default Re: How to run engraving program at different depth
    Thanks Lucas for taking time to help. Will try it today.
