get the g-code from any image
Results 1 to 7 of 7
Thread: get the g-code from any image
    Member hasanqo's Avatar
    Dec 2019
    Default get the g-code from any image
    hi ... i need idea for get the g-code from any image so that to apply it directly to machine is that possible ???
    Member awerby's Avatar
    Apr 2004
    Default Re: get the g-code from any image
    If there's really G-code in your image file, Optical Character Recognition should be able to recover it. Check it carefully for errors first, though - a missed decimal point or bad number could do a lot of damage.
    If you're really talking about converting a 2D image to a heightfield mesh and generating code to carve it, DeskProto is my favorite tool for that. We sell it for the same price in number of dollars that it's priced in Euros (although that may change if the dollar keeps falling).
    Dec 2019
    thanks ....actually i deal with 2d and need to convert image to g-code and use cnc plotter with arduino .
    May 2005
    canada
    Quote Originally Posted by hasanqo View Post
    "any image" is a tall order. There's a big difference between bitmaps and vectors for example and there are formats like jpeg which are a special type of bitmap.
    Vector (like .SVG) to g-code not difficult.
    Good resolution B&W .jpg to g-code a little more difficult.
    Colour .jpeg to g-code, difficult. I'm not sure if any single software does a very good job of that. I've tried an online converter and was not impressed.
    Anyone who says "It only goes together one way" has no imagination.
    May 2005
    canada
    Said more simply a photograph of a butterfly with a complex background and a clip art butterfly are both images. One is easy the other is not.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
  7. #7
    Member routalot's Avatar
    Dec 2003
    Those of us who use LinuxCNC will be aware that imported images can be converted to Gcode by a couple of mouse clicks.Not something I need to do often,but occasionally useful.
