CYCLE84 USING ANGLE HEAD 90 °
Results 1 to 3 of 3
Thread: CYCLE84 USING ANGLE HEAD 90 °
    Member Ivaan's Avatar
    Jul 2020
    Post CYCLE84 USING ANGLE HEAD 90 °
    Hello everybody!
    I,m new using this plataform to be in touch with colleagues about CNC programing and I hope does anybody can help me.
    I will machining one drill and and thread (M8 X 1.25) using an angle head 90° with a tap, the hole is in G19 reference plane XY, thread axis is paralel to X axis of the machine, is the first time that I need to machining a hole that is not perpendicular to Z axis.
    My doubt is:
    If I program G19 before the CYCLE84 then all the parameters for the cycle will be reference to that plane (G19 YZ)? for example for the parameter "DP" final Depth the machine will move in X axis because I selected G19? works like this? if not how I have to program it?
    Jul 2010
    South Africa
    Default Re: CYCLE84 USING ANGLE HEAD 90 °
    hi,
    welcome
    you can start by informing us about the machine make & model + cnc control type & model.
    el's we have no clue
    Jul 2020
    Post Re: CYCLE84 USING ANGLE HEAD 90 °
    Thank you norbert the machine is SW BA W06 -22 and CNC control is SIEMENS 840D Solution line
    Attached Thumbnails Attached Thumbnails CYCLE84 USING ANGLE HEAD 90 °-angle-head-sw-png
