I keep getting an error stating that there is a c axis code in spindle mode this is my program i rough and finish the part and then do some c axis movements and then finish the part again to get rid of the burr...the first finish part of the program works fine and is identical to the 2nd one so I don't know whats going on. it's stopping at the G3 code...If i change the G3 code to G1 it works, but I'm not sure why it doesn't work now! Any help is appreciated! Also this is on a Fanuc 31i Model B controller....Doosan Puma TT1800SY machine
O0302 ( 8 TON ID CORE-Upper Stream.NC )
(UPPER TURRET)
(DATE: TUESDAY, 02 JUNE 2020 - TIME: 16:01)
(MCX FILE - 8 TON CORE .mcam)
(JOB NUMBER - )
(PROGRAMMER - )
(T0909 TLS ROUGHER INSERT - NONE)
(T0303 1/4 FLAT ENDMILL DIA. - 0.25)
(T0101 TLS CUT OFF TOOL INSERT - GC-4125)
Most probably one of the command in N3 (OPERATION #8) is not reset correctly so N4 gives error after N3 but N2 is ok.
I throw this like randomly and im not sure it will fix but in N3 you have a bunch of canned cycles G98 but no G80 (cancel canned cycles)
Try to add a G80 at the end of N3
Do you need a M5 P11 before you start main spindle turning again? on the doosans I run M5 tells it main spindle M35 tells it live tool, we only have main spindle and live, no sub spindle
