G81 cycle problems
Results 1 to 5 of 5
Thread: G81 cycle problems
    Registered psyon's Avatar
    Dec 2018
    Default G81 cycle problems
    Hi Friends,
    We're using a G81 drilling cycle on plastic parts but we're finding the dwell at the bottom of the hole is too long and starts melting the plastic. We would like to remove the slight dwell time at the bottom of the hole which seems to be built into the canned G81 cycle.
    Does anyone know if a parameter of the G81 cycle can be changed to remove the dwell? Will I need to create my own canned cycle to accomplish this?
    Thank you for your help.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: G81 cycle problems
    If you have a P value.. set it to zero
    else, program the cycle longhand using a G01 plunge with a G00 to retract...
    if there is still a lag at the bottom of the hole, then the issue is with the machine or controller
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by psyon View Post
    Hi Friends,
    What is the machine control you are using, normally there is no dwell with a G81 that is just a Feed in Rapid out cycle
    How do you have the line of G-code written in your program
    Mactec54
    Dec 2018
    Fanuc 11m controller
    This happens in the g0 block after g01.
    Problem occurs in rapid traverse after cutting traverse.
    Cutting feed is normal after cutting feed.
    Rapid traverse is normal after rapid traverse.
    G01 z-30. F100
    (Stop for about 2 seconds)
    G0 z30.
    May 2016
    Hi Pyson,
    Your code there has nothing to do with G81. I thought your question was about G81 drill cycle?
    Here is what a typical G81 drilling cycle looks like.
    T2M6 (DRILL)
    G17G21G40G49G54G80G90G98
    G0 X25. Y-20.
    G43 Z2.5 H2 S3050 M3 T3
    M8
    G98 G81 Z-30. R2.5 F100.
    X35.
    X50.
    Y-40.
    G80
    M9
    Those position moves are of course arbitrary.
    If you want to get better results out of what you have above, try staying in feed mode and not switching to rapid.
    G01 Z-30. F100.
    Z30.F8000.
    Plus I'm thinking if the control waits 2 seconds after the feed move and before the rapid move, the machine might have problems. Make the your machine is not stuck in Exact Stop Check Mode G61. Should be in regular cutting mode G64. Go into MDI and type in G64 EOB and hit cycle start. Then try your code again and see if there's any difference.
    Has anyone been messing with the parameters lately???
G81 cycle problems
G81 cycle problems
